How to compute the DPM tracks for 1-way coupled simulation using TUI command without using the Display menu?
March 17, 2023 at 8:59 am
FAQParticipantFor a 1-way coupling DPM simulation, the particle trajectories are computed only during the post processing. In order to avoid to call any Fluent graphical capability, it is possible to execute the TUI command: /solve/dpm-update to update the particle trajectories.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
