Tagged: 2021 R2, fluent, fluid-dynamics, fsi, General - FLUENT
March 17, 2023 at 8:59 am
FAQParticipantThis is a known issue that is being investigated as of 2022R1. As a workaround the Fluent results can be loaded into CFD-Post and by going to File > Export > Export the ASCII data can be exported
- Skewness in ANSYS Meshing
