March 17, 2023 at 8:59 am
FAQParticipantThis error is known to occur when assigning parameters to unitless quantities in Fluent 2019 R1 using the GUI. The workaround is to use the TUI to create and assign parameters to the appropriate variable. Keywords: parameter, interpolate_profile_thread, Fluent 2019 R1
- Skewness in ANSYS Meshing
