Issue: I’m getting an error: “too few arguments†for a call to the Update_Cell_Metrics function.
March 17, 2023 at 8:59 am
FAQParticipantResolution: Update_Cell_Metrics was changed to require 3 arguments. 1. param[in] c – cell local index in cell thread 2. param[in] t – cell thread 3. param[in] useStoredMetrics – whether face metrics is available for computation. Setting the (new) last parameter to FALSE should run the function as before. e.g.: Update_Cell_Metrics (c, tc,FALSE);
- Skewness in ANSYS Meshing
