March 17, 2023 at 8:58 am
FAQParticipantSCDM uses the term blend instead of loft. To blend surfaces: 1)Click the Pull tool in the Edit group on the Design tab. 2)Click the Blend option in the Options window.
- Skewness in ANSYS Meshing
