March 17, 2023 at 8:58 am
FAQParticipantIt is not possible to use more than one particle part for one case. This is a limitation of the EnSight Case Gold format. Particles are described as a “measurement” point cloud. The only known workaround is to use multiple cases for the different injections. EnSight can open up to 16 cases simultaneously. By referencing the same *.geo file in all *.case/*.encas files it is possible to limit the data volume. Then load only the particle part for all but the first case.
- Skewness in ANSYS Meshing
