March 17, 2023 at 8:58 am
FAQParticipantTo create and view a chart object: 1. Click Create Chart or select Insert > Chart. The Insert Chart dialog box appears. 2. Enter a name for the new chart object. Click OK. A detail view appears for the new chart object. 3. Edit the chart settings as appropriate for each tab: • General Tab • Data series Tab • Axes Tab • Line Display Tab • Chart Display Tab 4. Click Apply. The chart object appears under the Report object
- Skewness in ANSYS Meshing
