When trying to create a FlowPath in BladeEditor, I get the following error: Error: An internal has occurred. The Bounding Box evaluation for the contours failed. Conext: ansFClientBMBladeDesign::Execute FlowPath How can this be avoided?
March 17, 2023 at 8:58 am
FAQ
ParticipantThe sketches for the Inlet, Outlet, Shroud, and Hub need to be on the positive X side of the ZX plane. If the sketches are not on the positive X side, then this error can occur. Also, if any part of the sketch is not on the positive X side, then this error can occur. Please see the following for more information: https://www.youtube.com/watch?v=jKRzrj9d4gE
- Skewness in ANSYS Meshing
