During a multi-body dynamic analysis, what does the following message mean? x JOINT ELEMENTS WITH LAG MULT OPTION DO NOT SATISFY JOINT CONSTRAINT CONDITIONS
January 25, 2023 at 7:34 am
FAQParticipantThe “LAG MULT” is short for “Lagrange Multiplier,” which is the method used to impose the kinematic constraints in the joint elements. When trying to find a solution, this message indicates that the MPC184 joint DOF have not converged within some tolerance.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
