January 25, 2023 at 7:34 am
FAQParticipantQuestion: Is it possible in ANSYS to perform a seismic analysis on a free standing/non-anchored structure? We’re looking at an equipment rack that is on 4 short legs and is not bolted to the ground. I have used ANSYS in the past to analyze an equipment rack that was bolted to the ground using a modal analysis followed by a response spectrum analysis. Answer: Typically, “seismic” = “base excitation”, and “base excitation” = “base is constrained and excited”. So the answer is no, typically a free-standing system does not have a seismic excitation in a Response Spectrum Analysis.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
