In a response spectrum analysis (RSA), are the combined results automatically written to the results files (file.rst)?
January 25, 2023 at 7:34 am
FAQParticipantNo. Combining the modal results is a post-processing operation that is performed by inputting the modal combination file (/INPUT,file,mcom). The modal combination file contains a series of MAPDL load case commands. After issuing those commands, the combined results are stored in memory. RAPPND can be used to append the results in memory to the results file.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
