Tagged: 19.1, fatigue, mechanical, stress, structural-and-thermal, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantGenerally, it is not recommended to use von Mises stress for fatigue analysis because it only takes positive values and doesn’t account for any compressive mean stresses. Instead, you may use components stress such as max principal stress and signed von Mises for fatigue analysis.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
