January 25, 2023 at 7:34 am
FAQParticipantThe unbalanced mass is defined by a force, where the force is associated with the mass and eccentricity (distance from point to center or ‘rotating radius’ in WB Mechanical terms). We do it this way because we use a stationary frame of reference, so the geometry must be axisymmetric since it is not actually ‘rotating’ in the simulation, but the effect of rotation is accounted for in the gyroscopic damping matrix. In a similar way, the unbalance force must be applied to the center, and based on the real and imaginary components, the effect of the unbalance (via forces) is applied to the system.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
