January 25, 2023 at 7:34 am
FAQParticipantTwo materials laws can be considered when modeling foams : – Ogden foam model (for more information, refer to Ansys Help Material Reference / Nonlinear material properties / Hyperelasticity / Ogden compressible foam hyperelasticity) ; – Blatz Ko model (for more information, refer to Ansys Help Material Reference / Nonlinear material properties / Hyperelasticity / Blatz-Ko foam hyperelasticity). If the foam can be considered as little compressible, usual hyperelastic models can be used.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- Hyperelastic Simulations
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
