How does ANSYS Fatigue Tool calculate the alternating stress, mean stress and stress ratio for non-proportional loading?
January 25, 2023 at 7:34 am
FAQParticipant1. Calculate alternating and mean stress tensors. Each component of the alternating stress tensor is (max-min)/2 and each component of the mean stress tensor is (max+min)/2 from each analysis. where “max” is the maximum component stress value at a point between the two analyses, and “min” the minimum component stress value at the same point between the two analyses. 2. Find the max principal stress from each stress tensor, an alternating one “alt” and a mean one “mean”. 3. Stress ratio R = (mean-alt)/(mean+alt) Note the stress ratio is calculated internally for the purpose of querying the SN curve for the material. The alternating and mean stresses described above are output under the fatigue tool under solution combination. For more information on how to setup non-proportional loading see the training material for the Mechanical Fatigue Module.
