Mechanical Explicit jobs are getting struck or hanging or not solving but static structural jobs are running.
January 25, 2023 at 7:28 am
FAQParticipantWhile VPN is enabled the explicit jobs are not running due to IPV6. Disconnecting VPN and after enabling IPV4 both explicit and static jobs are started working.
