Question: When launching Electronics Desktop I encounter “The procedure entry point EnumDynamicTimeZoneInformation could not be located in the dynamic link library ADVAPI32.dll.”
January 25, 2023 at 7:28 am
FAQParticipantAnswer: The EnumDynamicTimeZoneInformation function under ADVAPI32.dll is not supported with Windows 7. The solution is to work with the same versions you have been using, or to update your machines to a newer operating system.
