January 25, 2023 at 7:17 am
FAQParticipantThe mean diameter with the same ratio of volume to surface area as the entire ensemble is known as the Sauter mean diameter. The Sauter mean diameter is used in Fluent to describe the interfacial area concentration. This is an important parameter for predicting mass, momentum and energy transfers through the interface between the phases. Population Balance Methods in Fluent allows the predication of the Sauter mean diameter of the disperse phases and hence a more accurate modeling compared to the monodisperse framework.
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
