January 25, 2023 at 7:16 am
FAQ
ParticipantUse the Scheme commands below to ignore the secondary gradient of Heat Flux. It is effective in improving convergence of the energy equation in cases with high skewness of the mesh. For the entire region: (rpsetvar ‘temperature/secondary-gradient? #f) Only for the Wall: /solve/set/expert/use-alternate-formulation-for-wall-temperature? Yes Only for Shell Conduction: (rpsetvar ‘temperature/shell-secondary-gradient? #f) Note the parentheses are required for the input.
- Defining heat transfer coefficient (HTC)
- Thermal Analysis of a Radiator Using Ansys Fluent
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- What is the difference between internal and external emissivity?
- How to use Thin Walls with Thermal boundary conditions?
- How to add comments to journal file so that I will know what each entry does?
