Getting following error during particle track. Error: CAR: invalid argument [1]: wrong type [not a pair] Error Object: #f
Tagged: 18, fluent, fluent-post-processing, fluid-dynamics, post-processing
January 25, 2023 at 7:16 am
FAQParticipantThis error comes because no boundary zone is selected under ‘Release From Surface’. So injection definition is not complete. Please select ‘inlet’ (or any other boundary zone from where particles are injected) under ‘Release From Surface’. Then click ‘Ok’. This will complete injection definition and then you can track the particles.
- Skewness in ANSYS Meshing
