January 25, 2023 at 7:16 am
FAQParticipantThis behavior pops up occasionally if a model has many entities that have been copied and pasted, or internalised and externalised. The quick solution is to copy and paste all the geometry into a new, empty design. This will remove all the background information that’s slowing the model down.
- Skewness in ANSYS Meshing
