General
General
How to solve supersonic Laval nozzle flows efficiently and quickly?
    • FAQFAQ
      Participant
      Use one of the the following solving strategies: Strategy 1 (robust), works only for subsonic outlet, i.e. the outlet must be downstream of the shock: 1) Create 2 meshes for the Laval nozzle geometry: 1 quite coarse mesh for getting an initial solution and a fine mesh for getting the final solution 2) Apply CFD best practice guidelines to the mesh generation process (quality and density of meshes) to minimize numerical errors 3) Start with the coarse mesh: a) Set the outlet pressure b.c. and the initial pressure to the value of the outlet b.c. pressure. Set initial velocities to nearly zero and initial temperature to the inlet (total) temperature. b) Define a ramp function for the inlet total pressure to ramp up from the value of the outlet pressure to the final desired inlet total pressure value. This ramp function can be written in CEL form as follows: InletPressureRamp = min( (OutletPressure + (InletFinalPressure – OutletPressure) * aitern / RampIterations) , InletFinal Pressure) with “aitern” being the solver variable for the accumulated iteration number and “RampIterations” being the number of time steps until the final inlet pressure should be reached. After the final inlet presssure is reached, the solver continues with a constant (final) inlet pressure. c) Get a converged solution of the flow field on the coarse mesh. 4) Interpolate the coarse mesh results onto the fine mesh. 5) Get the final converged solution of the supersonic flow field on the fine mesh. Strategy 2, works both with sub- and supersonic outlet: 1) Create a coarse mesh, if desired to get initial solution. 2) Define an initial guess that contains different pressure, velocity and temperature values for different sub- and supersonic regions. The values can be either taken from tables on 1-dimensional non-viscous supersonic flows or from the following web link: http://www.aoe.vt.edu/~devenpor/aoe3114/calc.html 3) After getting a converged solution on the coarse mesh, interpolate the solution to the fine mesh and continue the calculation to get the final fine mesh solution.
