November 2, 2022 at 9:17 am
SolutionParticipantThis video shows how to use the Weld Tool to create new weld surfaces between midsurface and shell bodies that cannot be extended. Extending surfaces to intersect with each other is often the optimal way to create a conformal mesh. When the midsurface shells cannot be extended properly, the Weld Tool is used to join the bodies correctly.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Detect Tool
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- FAQ – Share Topology is now available in Discovery 2021 R2
- Split Face in SpaceClaim
- Selecting all inner faces of a body
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
