September 26, 2022 at 10:15 am
FAQParticipantDiscovery Getting Started Tutorials
1 . Getting Started – User Interface
2. Getting Started – Structural
a. Structural Simulation of Aircraft Simulation Mounts
b. Structural Simulation of a Rally Truck Suspension
c. Structural Simulation in a Flow Valve
d. Structural Simulation of a Rally Truck Suspension (2021 R2)
3. Getting Started – Fluids
c. Fluids-Solid Heat Transfer (CHT)
d. Fluid Flow in a Air Filter (Porous Media)
e. Fluid Volume Extraction with Smart Bodies (Cutter Bodies)
4. Getting Started – Modal
5. Getting Started – Thermal
a. Thermal Analysis on a Cable Router
b. Fluids-Solid Heat Transfer (CHT)
c. Fluids-Solid Heat Transfer (CHT) with Radiation
6. Getting Started – Topology Optimization
a. 2021R2 – Automotive Bracket
b. 2020R2 – Automotive Bracket
Discovery In-Depth Tutorials
1. In-Depth – Fluids
a. Duct Model
c. LiveGx Solver with Polyhedra Mesh
2. In-Depth – Structures
a. Structural Simulation of a Rally Truck
3. In-Depth – Electronics
Geometry Prep Tutorials
1. Getting Started
a. Pull
b. Move
c. Fill
d. Sketch
e. Combine
f. Repair
2. Geometry Prep for Structures
3. Geometry Prep for Fluids
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- Applying Thermal Conductance
