September 26, 2022 at 10:00 am
SolutionParticipantThis example is taken from Cornell University’s ANSYS AIM Learning Modules
Problem Specification
Consider the hollow cylinder pictured below with outer radius (ro=3.25in), inner radius (ri=1.75in) and length (l=120in). The temperature at the inner radius of the cylinder is 400 degrees Fahrenheit while the outside radius of the cylinder is 80 degrees Fahrenheit with a coefficient of heat transfer of 0.04 Btuh*ftF.
In this tutorial, we will utilize Discovery AIM to find the temperature throughout the pipe, total heat flux and directional heat flux.
Pre-Analysis
The governing equation for axisymmetric radial heat flow for a homogeneous cylinder with inner radius ri and outer radius ro is displayed below. Note that the following equation assumes that the cylinder is long enough for end effects to be ignored.
In the above equation k is the thermal conductivity, A is the surface area, T is the temperature, r is the radial position and Q is the heat generation per unit area.
For the given problem there is no heat generation, thus the governing equation can be solved easily. The solution for temperature as a function of radial position is displayed below.
Geometry
In this video, you will learn how to create a hollow cylinder.
Mesh
In this video, you will learn how to specify body sizing and generate a finer mesh for the hollow cylinder.
Physics Setup
In this video, you will learn how to define solid thermal conditions to the model.
Results Evaluation
In this video, you will learn how to evaluate temperature and heat flux contours, and heat flux vectors.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
