Legacy Products
Legacy Products
Discovery AIM tutorial – Fluid Flow Through a Transition Duct
    • SolutionSolution
      Participant
      In this tutorial, the common transition duct pictured below will be the subject of our simulation. These are commonly found in office buildings and are sometimes used to vent air into the atmosphere. For this example, the temperature at the inlet of the transition duct is 73 degrees Fahrenheit. If air travels at 33 feet/sec at the inlet, find the velocity vectors inside the transition duct and find the pressure exerted on the transition duct from the air within.
       width=
      Download the file here
      In this video, you will learn how to import the geometry in Discovery AIM and how to generate mesh in the computational fluid domain.
      In this video, you will learn how to specify fluid flow conditions.
      In this video, you will learn how to evaluate velocity vectors, Total Pressure and Temperature contours in the flow domain.
