September 26, 2022 at 9:53 am
SolutionParticipantDownload the file here
The attached Discovery Compatibility Utility can be run to confirm if your graphics card is capable of running ANSYS Discovery.  To use it, download and extract the contents of the zip file, and run the DiscoveryLCompatibilityUtility executable to obtain a hardware report.Or you can find this utility at the following locations in the product installation directory,
Program Files\ANSYS Inc\v241\Discovery\CudaCheck\DiscoveryCompatibilityUtility.exe
- Ansys Discovery Hardware Requirements (2025 R2)
- What’s New in Ansys Discovery 2025 R2
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery Subscription license – Command line options
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- ANSYS Discovery: Compatibility Utility
