September 26, 2022 at 9:45 am
Watch & LearnParticipantDiscovery 2020 R2Â has a single, easy to use and modern user interface for performing solid modeling, real-time simulation as well as high fidelity simulation.
Discovery 2020 R2Â is based on SpaceClaim architecture and hence you will find most of the solid modeling tools under menus like Design, Facets, Prepare, etc. In spite of new interface, the modeling tools function in the same manner as they do in SpaceClaim. The only difference is the location of tool guides and tool options which are located under Heads Up Display (HUD) of Discovery interface.
Hence all SpaceClaim tutorials available on this Discovery Community Forum are applicable to Discovery. For quick reference, below is the direct link to the SpaceClaim tutorials.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Detect Tool
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- FAQ – Share Topology is now available in Discovery 2021 R2
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Split Face in SpaceClaim
- Selecting all inner faces of a body
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
