September 26, 2022 at 9:33 am
FAQParticipantAnsys Discovery includes the ability to create Discovery simulation projects directly from Autodesk Fusion 360 design studies. When a Fusion design study is imported, Discovery will create a new simulation for each load case, including all loads, constraints and materials for the load case. The design may then be further simulated and modified from within Ansys Discovery.
- This capability is provided via a separately installed Discovery Addin. Click here to download the add-in installation package.
When Ansys Discovery is launched, the File menu will include a new ‘Import/Import Autodesk SDZ File’ entry.
For further information on how to export SDZ files or directly launch Ansys Discovery from Fusion, please refer to the following Autodesk Help pages:
- Export a created design study directly into Ansys
- Create a Fusion 360 Simulation data file for import into Ansys
To learn more about using Fusion 360 and Ansys products together, also see these classes from Autodesk University 2020:
- Discovery Downloads
- Ansys Discovery – Supported File Formats
- Release Notes- Previous versions
- Importing an Autodesk Fusion 360 Design Study into Ansys Discovery
- Ansys Discovery: Transient Simulation
- Ansys Discovery: Creating Custom Shortcuts
- Top New Features in Ansys Discovery 2026 R1
- Ansys Discovery: Customizing the Ribbon Tab
- Ansys Discovery 2025 R1 Capabilities chart
- Saving, Importing and Exporting User Settings
