July 4, 2022 at 7:00 am
Watch & LearnParticipantIn this video, the simulation of the modified design in HFSS 3D Layout reveals improved results. Insertion Loss and Return Loss reports are generated for the modified design. When compared to the initial design, it’s found that the coupling between the offending signal and antenna is reduced significantly in the modified board. The return loss report predicts good results so despite making changes to the geometry, the PCB’s intended functionality and operation remain largely unaffected. The second mitigation scheme of settling on the slower data rate over the fast data rate is also shown.
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- ANSYS HFSS: Creating 3D Components
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to Set “Non-Model” Property to an Object in 3D Layout
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- How to Create Bondwires in 3D Layout ?
