July 4, 2022 at 6:59 am
Watch & LearnParticipantThis is part 2 of two-part video designed with FSAE student teams in mind. In this video, you will learn how to set up a model in Maxwell to analyze WPT system, and calculate self and mutual inductances as well as losses in shields. You will also learn to set up a parametric analysis for offset between coils. For questions and support, join the Ansys Student Community: https://studentcommunity.ansys.com/
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- Cloud Computing from Electronics Desktop
- What are the available boundary conditions in Maxwell?
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
