June 6, 2022 at 10:51 am
Watch & LearnParticipantIn this video, you will learn how to prepare a FSAE Car in SpaceClaim. Features demonstrated include: Prepare Enclosure, Create Bodies of Influence, and Named Selections. For questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- Create Sections in Meshing
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is the difference between patch dependent meshing and patch independent meshing?
