June 6, 2022 at 9:58 am
FAQParticipantLower-order elements are prone to shear locking in bending-dominated problems. Model may be undergoing shear locking when using SOLID85 elements. Shear locking causes the elements to be over stiff in bending leading to high frequency in Modal. This can be controlled by Keyopt2. One can resolve this issue by using simple enhanced strain formulation-> keyopt (2)=3 or 2. Higher order elements 95 & 186 have less issues of shear locking. Description of elements formulation can be found in ANSYS Help: // Element Reference // 5. Elements for Stress Analysis // 5.1. Continuum Stress Elements –> 5.1.2 Element Technologies
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
