How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is 10,000 modes.
June 6, 2022 at 9:58 amFAQParticipant
You can do two separate modal (each with less than 10,000 modes) and two separate spectrum analyses based on the modal analyses and then SRSS combine the results. To capture the full modal range, you need to request 10,000 or fewer modes in the first modal analysis and specify the end frequency (FREQE) from the first modal analysis as the beginning frequency (FREQB) for the second modal analysis. You then need to do two separate response spectrum analyses based on the two separate modal results. After each spectrum analysis, you can use RAPPND to write the results to an rst file. Finally, you can use a load case combination to SRSS the results from the two response spectrum analysis to calculate the combined result for the full modal range. You can use the FILE command to toggle between the two spectrum rst files within /POST1.
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to include effect of bolt pretension in a modal analysis?
- In a Modal Analysis of Mechanical, why aren’t the Participation Factors Summary under Solution Information displayed?
- Is it possible to perform a sine-on-random vibration analysis in either Mechanical or Mechanical APDL?
- ANSYS Mechanical: Vibration Housing Noise
