June 6, 2022 at 9:58 am
FAQParticipantThis message indicates that the two nodes that define the spring connection are coincident. The length of the spring connection must be greater than 0.0 with a tolerance of 1e-8 mm. You can view the Reference and Mobile coordinates in the details of the spring to calculate the length of the element.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
