Modeling & Meshing
Modeling & Meshing
How can you change the tolerance for boolean operations in Mechanical APDL?
    • FAQFAQ
      Participant
      Check the default value of tolerance for boolean operations through BTOL, STAT command. Provide a tolerance value about 1/20th to 1/10th of the minimum keypoint distance using the command “BTOL, tolerance value”
