When I change the parameter in SpaceClaim, the geometry change is updated in Mechanical, but the parameter set value does not update.
June 6, 2022 at 9:58 am
FAQParticipantWhen parameter value is changed from SpaceClaim, it can update the Mechanical model. But the parameter set value in Workbench is not updated. To update, there is an option ‘Update Parameter’ in SpaceClaim under the ‘Workbench’ tab. This will push the updated value to Parameter set.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
