June 6, 2022 at 9:58 am
FAQParticipantThis can be done in two steps
1. Create a journal to open the file, update (to solve) and save. You can create a journal on a dummy file and later change its file names.
• Open Ansys WB. Go to file >> Scripting >> Record Journal. Save the journal file and provide the name.
• Open Dummy project file, update the project and save with other name.
• Go to file >> Scripting >> Stop Recording journal
• Go to journal file. Change the name of WB project to actual WB file and name to save after update.
• Change the journal extension from .wbjn to .py2. Use the following template to input shell commands to open WB and run journal in batch mode:
<< Path to open WB .... /v172/Framework/bin/Linux64/runwb2 >> -B -R << Path to open journal (.py) file >>For more information, please refer ANSYS Help > Customization Suite > ANSYS AIM and Workbench Scripting Guide > Scripting Overview > Journaling and Scripting Guide.
