June 6, 2022 at 9:57 am
FAQParticipantUse Selection Information tool in Mechanical to view information about Mass, Volume, Centroid, Nodes and Elements of multiple bodies. The tool is located adjacent to Worksheet button on the toolbar. The bodies must be selected in Graphics window and not in the Tree Outline.
