Why doesn’t the total deformation plot scale look correct when compared to the ruler located at the bottom of the Graphics window?
June 6, 2022 at 9:57 am
FAQParticipantThis is due to when results are set to magnified scale. Check the scale of the results is set to true scale (factor =1). Also check for directional deformation plots. Total deformation will give only a positive number whereas directional deformation plot will reveal the behavior of deformation more explicitly.
