June 6, 2022 at 9:57 am
FAQParticipantDifferent colors are employed in 2019R1 to bring out the differences between shared systems. Links that indicate shared data between systems are shown in blue with square terminators. Links indicating data transferred from an upstream system to a downstream system are represented in ‘Fuchsia’ with round terminators. A more detailed discussion of different kinds of links can be found in WorkBench Users Guide R2019R1 [Overview -> The Project Tab -> The Project Schematic -> Project Schematic Links].
Keywords: 2019R1, WorkBench, Connections, Colors
