June 6, 2022 at 9:57 am
FAQ
ParticipantOne can select a particular node/nodes in Mechanical and right click to select option ‘Create Named Selection’. If the nodes are to be selected from surface/bodies, then create a Named Selection for the particular Surface/body. Right click the Named Selection and select ‘Create Nodal Named Selection’
