June 6, 2022 at 9:57 amFAQParticipant
One can select a particular node/nodes in Mechanical and right click to select option ‘Create Named Selection’. If the nodes are to be selected from surface/bodies, then create a Named Selection for the particular Surface/body. Right click the Named Selection and select ‘Create Nodal Named Selection’
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
