June 6, 2022 at 9:57 am
FAQ
ParticipantYou can use a Solution Combination to find the difference between the two models.
First, right click on the Model Object in the Outline Tree and insert a Solution Combination Object into the Outline Tree. In the Solution Combination worksheet window, right click on the header grid and add a row. In the created row, specify a coefficient of 1.0, the applicable environment, and the solution time point. Repeat the above procedure for the result set with the different set of boundary conditions, but specify a coefficient of -1.0.
These steps will create a result set that is the difference between the environments. After defining the Solution Combination, RMB on the Solution Combination Object in the Outline Tree and insert the desired post-processing action (i.e., plot directional deformation). Then RMB and solve the Solution Combination.
