June 6, 2022 at 9:30 am
Watch & Learn
ParticipantIn this video, we will talk about how to remove failing design points in DX. Sometimes during a Design of Experiments run one or more of the Design Points may fail to update. If a sufficient number of design points have successfully completed then we may want to proceed with the next steps of creating a response surface or optimization, but first, we would need to delete the failed design points.
