- All Categories
- Fluids - Postprocessing
- How to automatically export report figures in the workbench without any scripts?
June 6, 2022 at 8:33 am
FAQ
ParticipantIn the Workbench while dealing with design studies and figures have to be exported without saving the result files:
1-Create your Workflow (Geometry>Mesh>Fluent or CFX > Result)
2-Define some Input and Output parameters
3-Define a dummy Output parameter in CFD-Post
4-In CFD-Post under Report deselect all features and enable only the figures to be exported
5-In the Workbench go to the properties of Results container and enable “Publish report”
6-Define some design points by altering the input parameter
7-Update design points The pictures are then saved in the project under ~yourproject_filesreport_files The most important step is to define the dummy output parameter in CFD-Post otherwise the figures won’t be exported.
Keywords: parameter, CFD-Post, Report
- ANSYS Fluent: Scene and Animation Creation
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- Add Annotation to Graphics Display within Fluent
- How do I automatically export figures generated in CFD-Post from Workbench?
- How can I hide the legend or colormap for a Fluent plot?
- ANSYS CFX: User Locations in Transient Simulations
