June 6, 2022 at 8:32 am
FAQParticipantTGrid / Fluent Meshing can output files for each boundary you have. Select [Write] in the [File] menu and select [Boundaries]. Then, select the Boundary you wish to output in the Boundary Zones and output it.
- Skewness in ANSYS Meshing
