October 27, 2024 at 1:50 amDatoSubscriber
There is something wrong with dimension display in Sketch mode in a .scdoc file but it is normal before designing in this .scdoc file.
The large space should be a dot but it doesn't display. However, the dimension display becomes normal if I new a design.
I have tried to reboot SC but it doesn't work. I have tried changing something in Detail tab but it still cannot recover.
Any suggestion would be a great help.
Regards.
October 29, 2024 at 5:30 amCharudatta BandgarForum Moderator
This could be possible due to the regional language you have set in Windows. Can you check once? The decimal operator could also be the reason.
Regards
Ansys Innovation Space
407
264
201
162
