February 27, 2024 at 2:13 pm
bpamidemarri
SubscriberHi,
I am using ANSYS 2024R1. I could not able to add base cases for solution combination in worksheet type-Multiple. workspace is freezing(Showing white screen) while i click on the solution combination. I have graphic card of NVDIA Quadro RTX 4000.
Please provide solution/ suggest if any setting to be updated.
Below snap is for your reference.
Thanks.
March 4, 2024 at 3:42 pm
George Karnos
Ansys EmployeeHi,
As this looks to be Graphics related, I would recommend to check for latest Nvidia driver for graphics card and install that driver to see if this helps. -
April 9, 2024 at 1:28 pm
Yidu Di
SubscriberHi,
I met also the same problem. When the Worksheet type is set as Single or Envelope, the worksheet can be schown as normal. Only for Multiple the worksheet does not show up at all, although I clicked on the Worksheet button.
Could anyone give a hint about it?
Thanks!
April 11, 2024 at 4:18 am
- The topic ‘Worksheet not working for Solution combination’ is closed to new replies.
5799
