September 6, 2018 at 2:13 pm
John1375
SubscriberHello everyone, I get these errors ( in ANSYS WORKBENCH
whenever click on the solution to solve
no matter what kind of project)
3.An error occurred when the post processor attempted to load a specific result. Please review all messages.
2.The result file cannot be opened.
1.Current result file may not contain requested result data . Please clear the solution and solve again.
can anyone help me with this issue?
September 6, 2018 at 2:14 pm
Forum ModeratorMoved to new thread.
Check you've saved the files/results and that you have write permissions to that folder and there are no "odd" characters in the tree label. Also check your graphics card is supported.
September 7, 2018 at 2:49 am
Sandeep Medikonda
Ansys Employee -
January 25, 2019 at 12:26 am
CalebOU
Subscriberrwoolhou,
How do you check if your graphics card is supported? Is the following all inclusive of supported GPUs?
https://www.ansys.com/-/media/ansys/corporate/files/pdf/solutions/it-professionals/platform-support/gpu-accelerator-and-co-processor-capabilities-19.pdf?la=en&la=en
I have a Nvidia Quadro 600, since that does not show up on the list and I am getting the exact same error and warning messages, is the only way to get a new GPU?
January 25, 2019 at 11:02 am
Forum ModeratorIf the card/chip is not on the list it means it's not been tested. It doesn't necessarily mean the card won't work. What you will need to do is make sure you're launching the software with the correct drivers: it may be trying to use the basic Intel drivers.
The other thing to do is create a very simple workflow using (for example) a cube and see if that also fails.
February 7, 2019 at 2:49 am
CalebOU
SubscriberHow do you ensure the software is launching with correct drivers? Are you talking about Ansys software or software for the GPU? And the model works on a virtual lab I have access to, so it is something specific to my computer. I also upgraded to a tested GPU, is there a way to turn off GPU acceleration in Ansys so it just solves as it would on a virtual machine?
February 9, 2019 at 2:18 pm
peteroznewman
SubscriberThe drivers are for the graphics cards or GPU. Please say exactly what model Graphics Adapter for display you have and if you have a second GPU for computation, what exact model of GPU that is.
You can turn GPU acceleration on or off in Mechanical by opening Tools > Solve Process Settings > Advanced and on the Use GPU line, setting it to None.
February 12, 2019 at 12:09 am
CalebOU
SubscriberI have an NVIDIA Quadro P2000 which I am trying to use for computation as well as display. It is hooked up to my motherboard via PCIe3x16. I do not have a second GPU. I got the latest driver for this GPU from Nvidia's website. I have tried turning on and off the GPU acceleration and get the same 3 messages in the original post every time whether it is on or off. I am currently accessing my license by a VPN, I have looked but not found any useful threads that relate that to the 3 messages and this seemed the most promising until I updated to the P2000 and still got the same results.
Again, I have access to a virtual computer which also uses the same VPN to access the license, I have no error messages with the same file, making me think it has something specifically to do with my computer. Possibly a firewall somewhere that I cannot see but will not let the post processor to operate correctly, but that is just an idea. I have write permissions to every folder I have my .wbpj files saved in.
February 12, 2019 at 11:50 am
Forum ModeratorAssuming you have a Workbench icon right click on it, and part way down the list is an option "Run with graphics processor" in Win7, make sure it's set to the NVIDIA card.
February 13, 2019 at 3:02 am
CalebOU
SubscriberI am running on Windows 10 so there is no option "Run with graphics processor" when I right click the icon. I specified GPU acceleration using the ANSYS Mechanical APDL Product Launcher, but that did not work either. I do have a dual CPU (2 Xeon E5-2670), could there be a problem with ANSYS not recognizing that there are 2? Or does it just focus on number of cores and not pay attention to number of CPUs?
March 10, 2019 at 9:47 pm
Pawel11
SubscriberHi, did you manage to resolve the issue somehow? - I'm having the exactly same problem.
March 14, 2019 at 11:32 pm
CalebOU
SubscriberUnfortunately not yet. I've been asking my IT person who has been walking me through several License Preference settings, but all those have been correct so far.
July 29, 2019 at 4:42 pm
adam1992
SubscriberHas this been resolved??
I am having the same issue. I have even followed a simple online tutorial step by step and receive the same error messages.
Adam
September 5, 2019 at 10:43 am
huayra
SubscriberYou fix it?
September 5, 2019 at 11:47 am
peteroznewman
Subscriber@huayra,
There are several different problems mentioned in this discussion. Please start a New Discussion and explain your problem.
December 17, 2019 at 8:37 pm
kaopw
SubscriberMy solution is to move the whole project folder to desktop and everything works.
Previously I leave my project in a folder where synced with google's "Drive File Stream" (not Backup and Sync). The path looks like G:My DriveData...... (maybe the space cause the problem?)
Not sure what exactly the problem is but suspect either of following problem:
- Conflicts with Google Drive
- Path name which contains space might cause problem sometime
December 18, 2019 at 12:00 pm
Forum ModeratorSpaces occasionally cause problems, but more likely the path shown by Windows and as seen by ANSYS are slightly different.
December 31, 2019 at 4:50 pm
hamednik
SubscriberHello Everyone,
I have exact same problem when I am trying to solve my model on a remote HPC system. I created and solved my model on my PC but when I transfer it to the HPC system. The same error appears:
I have tried all the suggestions in this post, changing the path, turning off the GPU but none of them work. The model is very simple, a cube under compression. I really don't know what else I can do.
December 31, 2019 at 8:04 pm
peteroznewman
Subscriber@hamednik,
There are several different problems mentioned in this discussion. Please start a New Discussion.
December 22, 2020 at 1:15 am
February 19, 2021 at 7:44 pm
tcan
SubscriberThe error occurs when Ansys cannot write to a "result file".
That happens when the calculations are stopped for some reason, or while writing to the files, or the program has crashed during a solution, or maybe your files are located in a network drive and the connection is lost at some point. Some of the files or folders are locked, so you have to make them readable again.
Close all Ansys programs.
Right click Windows icon at the lower left corner and open "File Explorer".
Find where your Ansys project file *.wbpj is located.
Find all Project files and subfolders in this folder with typing *.* to the search box at upper right corner.
Select all files with Ctrl+A ,
Right click, open properties, click attributes read only check box, make all files read only and click Apply. Then uncheck read only box, click Apply and make all project files and folders readable again. At the end of this step, all files and folders must be readable.
February 22, 2021 at 5:27 am
tcan
SubscriberIn some cases, I have also experienced that in Engineering Data, some of the material properties for the Explicit Analysis (like stiffness or elasticity) is missing. From geometry, change all materials to structural steel and retry. In Engineering Data, Engineering sources, you have to load and select Explicit Materials only.
November 15, 2021 at 1:20 pm
tayyaba.bano
Subscriber.Hi,
I tried the same to make the result file readable, but unfortunate it does not work. I can see the text file in SYS-MECH 'solve.out' that the solution is completed but unable to load the result file.
Also I find file.err file in SYS-MECH. How can I resolved this issue further and load the result file.
Thanks
Tayyaba
- The topic ‘Workbench error’ is closed to new replies.
6420
